Headlamp fixings
    Headlamp fixings
    Morning all. Just a quick one. Can anyone tell me which screws to undo to detach the headlamps by clock position? I don't want to inadvertently muck up the settings, just install my new Cibies. My Haynes manual has gone walkabout and a search on google for a diagram has been fruitless. Even Rimmers catalogue illustration only shows a single adjustment screw position.
    Thanks in anticipation.
    David
    Hi David,
    You can see the small securing ones due to the ring they clamp on if that makes sense, the adjusting screws go in further.
    The Rimmers site shows it quite clearly.
    Jeff.
        David,
        IIRC, the clamping scres are 3 at ~120deg apart. Looking from the front, it should be clear which they are as they're keyhole shaped, so only need to slacken them off, few degrees of rotating the rim and it'll pop off.
        Did mine without needing to refer to manual, so I think you'll be OK.
        Jonno
          Many thanks, lads. Jonno, I swear I am getting senile. I completely blanked the fixing screw to the lower left in the picture when I looked at that picture.
            Everyone's allowed at least 1 Senior Moment a day
              I am way past that, Jonno.
                A picture paints a thousand words. Thanks, Neil. Much easier to see the difference than on the TR5 where the lamp is quite recessed.
