I have had my manual gearbox and overdrive unit (A type) rebuilt at not inconsiderable expense by a leading Stag specialist. Prior to the work it slipped out of 3rd gear on the over-run, some of the time. The overdrive unit worked fine and engaged and disengaged smoothly. On initial re-assembly the o/d wouldn’t work and so was rebuilt at additional cost.
On completion of the work and hand-over of the car, the gearbox still slipped out of 3rd, more than before, and the overdrive engagement was very jerky and fierce and almost certainly putting an excessive strain on the drivetrain. Naturally I requested this to be sorted and as I write the car is being worked on but I want to be as sure as possible that the diagnosis is correct and that the problem is remedied this time around. I have yet to receive a clear explanation but there is talk of a non-standard gearbox main shaft and bearing being the culprit.
Any thoughts as to the possible causes and remedies would be appreciated. Please don’t ask at this point for the specialist’s details as they are on the case and I would not wish to prejudice the final outcome.
PK
PK
