Need MOD propshaft
    Need MOD propshaft
    I need a MOD propshaft for J type. Seem to be couple for sale:-
    Rimmer CV jooint type which is converted SD1 item
    LD parts
    EJ Ward
    Does anyone have an experience of these or recommendations?
    EJ Ward says its like OE? Is it a tube in tube design?
    Thanks.
    Hi,
    I Had a Rimmers CV jointed one but it was faulty from new. I have ended up changing the bearing in the diff nose as it knocked it out!! I had my old unit refurbished and balanced and it is fine now £60.
    Tony
        Hi Paul
        I fitted an LD Parts one to our Stag last summer and have been happy with it to-date
        Bruce
          Had the prop for the 2000 refurbished by Proptech in Kidderminster last year for about £60 and it's been fine since. I appreciate that they might be a bit far away from you, but there are probably similar companies local to you that could refurbish yours.
            Need new one as I haven't got one! Planning to convert newly acquired Auto to manual and I cannot find a used one.
            EJ Ward looking a good bet at present.
              Ah I see. My solution probably not so helpful then!
                I've got a spare one - it was good when I took it off the car...............................
                4x4 Manual OD Stag
