I need to paint my Stag radiator. The tanks, tubes and fins are in good physical order but the paint is peeling a little on the fins and is patchy on the brass tanks. The rusty steel frame is the worst bit and is the main reason I am giving the whole a refurb.
I have some black rustoleum paint that I am going to use on the steel frame, but was wondering if anyone out there has experience of a suitable paint for the brass tanks and fins/tubes?
I have read some mixed reviews of the Eastwood radiator paint, so was wondering about other options?
Eastwood paint spec:
Standard engine paints are too thick for use on a radiator because they can interfere with heat transfer, and block air flow between the cooling fins. But Radiator Black Satin is specifically formulated for your radiator, heater core and air conditioning condenser.
Withstands 150°C (300 degrees F), also suitable for heater cores.
Acrylic enamel (85% gloss)
340g aerosol. 1 can covers about 6 square feet.
Available in Gloss or Satin Finish.
Keith
Keith
