Hi all you technical guys.
My Stag has until recently stopped nicely when required and I could slow down comfortably.
Now if I stomp on the brakes it works well and rubs its nose on the ground!!!!
If I press gently on the brakes to slow down slowly the pressure goes steadily until the pedal is nearly on the floor.
I do not seem to be loosing fluid.
Is this the fluid flowing back to the main cylinder or is it the Brake servo giving up the job and a new one beckons.
I have read that replacing the servo is a bit of a challenge and I do not do brakes generally and definitely not bleeding them.
Advice and guidance appreciated.
John H
John H
 Foot Brake pressure fade.
