Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 1 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Trying to access array offset on value of type bool in .../vb5/route/profile.php on line 74 idle speed - Stag Owners Club Forum
idle speed
    idle speed
    Hi all, I am having problems with my idle speed i cant get it to idle below about 1100rpm when warm. I have adjusted the idle screw to no effect. Return springs appear to be in good order. The previous owner has fitted another spring to the rocker cover so must be an on going problem.... Any ideas
    Air leak, split diaphragm in one of the carbs?
      OK thanks, any way of checking without to much bother
        Yes, undo dash pot screw tops and just leave them in place , rev engine and see if they both lift together at the same pace.
        Might be an air leak somewhere else though, one of the vacuum hoses split may be.
          Hello, first put off one trottle linkage, then adjust the idle screw of each carb seperately to synchronise idle for each carb. For that use a sync Tool. Then correct the linkage lenght exactely, use the adjustment screw at one of the trottle links.
          Kind regards Claus
          ps: Needle adjustments and diaphragms and needle valves had to be checked before...
            All i need to find now then is some time.....
