Help needed from anyone who is experienced with Stag starter motor problems.
Background :- My late 1972 Mk 1 had to be taken off the road nearly 3 years ago with a blown head gasket. Prior to that, in 2010 an E.J.Ward ‘click nothing’ device was fitted which resolved the occasional ‘click nothing’ problems during that year.
In 2016 after over haul, the starter motor started the car up perfectly with only one hitch. One of the Stromberg carbs was flooding. This was resolved in February this year when I fitted a couple of modern day Grose ball valves. However in February, now with the carbs no longer flooding, on attempted restart up – the dreaded ‘click nothing’ reappeared– so, starter and solenoid thought to be the problem after extensive direct wire testing to the starter motor - still, as always ‘click nothing’
So, reconditioned starter motor acquired and tested on the work bench with a ‘click whirring’ throwing the spinning pinion forward, as you would expect. So, off with the old starter and on with the new! Result now ‘click whirring’ – no engagement between spinning pinion and slip ring on the flywheel.
I know there is an early Mk1 starter, which this is not and the new one looks the same as the one that came off. Could this still be the wrong starter motor, or is something else wrong? Help required please!
Many thanks.
Many thanks.
. It's nice that members like you are only too glad to help Roger as you have done with me in the past, just a shame that's all. I am not affected because I am in touch with those I mentioned. Viva la forum.
