Think I've found a new, cheap and very simple method of hanging the exhaust at the rear subframe mounts.
Basically, I've used some exhaust strap readily available from Halfords, cut to the same length as one of the metal hangers and drilled it with two holes spaced exactly the distance between centres of the original strap.
I've used one each side rather than 2 on each exhaust and for the exhaust side of the moment a normal u clamp rather then the c clamp normally used.
Ive found that fitting in this way eliminates entirely any resonance from the exhaust through the subframe but also, the exhaust remains centralised in the subframe at all times.
I'll get some pictures but without wanting to deviate from originaility finding a way around the complex hanger and rubber bushes to me can only be an improvement and, because the hanger is not totally rigid it gets rid of the vibes.
