I bought a set of these a while back s/h low usage and seemed perfectly fine ,i have with help fitted them and they were easy enough but the n/s unit dropped the shaft form the inboard plunge joint twice .first time took it out and reassembled this time just wheeled it into the box and shut the door run out of time .I had no destructions with these but since after some searching last night found some poor install ones on the sc site .it appears that its possible they need spacers fitting behind the cup on the diff side to pack out ! i just thought they would be made to size for the stag obviously not .........has anyone else fitted these type and did they use a spacer and what was the method of determining a true length with radial allowance so as no lock up .
