Hello everybody, I hope you can help with a little info. I have just bought a very nice condition stag with a few 'niggles' to be sorted. The main one at the moment is the ZF conversion. I am very happy with the 'box and the actual gearchanges are almost imperceptable, it just keeps accelerating! However......good as it is, the PO has not changed the selector, so it still has the original 3 speed gate. This means that there is not enough travel to either select the lower two gears at one end, and Park has to be obtained by taking a 'run up' and bangingthe lever against the end of the gate!
What is the usual solution to this? is it just lengthen the slot to allow more travel, although this would ,I think, destroy the plastic surround, or does one normally fit a gate and surround from another vehicle, and if so , which one? Asking a lot, I know, but I'm sure if anyone knows, they will be on here.
thanks
thanks
