Hi,
I have oil in the vee so I'm going to slowly work through the various recommended causes to solve the problem.
Also, when I remove the oil filler cap there is no change in the engine revs so I'm replacing all the breather pipes and will fit a Rover P6 flame trap/breather in the rubber breather pipe - should I strip out the existing old gauze from the timing chain cover?
After this I'll clean the area off, dust with talc and see where the oil is coming from - the next areas to look at will be the timing chain cover gaskets, the distributor o-ring and (hopefully not) the water pump o-ring.
Thanks,
Jon
Thanks,
Jon
