Good evening all, i have had a momentary problem a couple of times, now, with my steering. When driving along it has suddenly seemed to lock, and taken a sharp movement of the wheel to be able to turn. This happens quickly but is a bit worrying. Wondered if anybody else ad experienced this, Thanks
steering problem
It's the bit with the white seals on it could not find any info on taking this apart and repairing, unless someone knows better?
it felt like it was stuck in the central position, ok on slight left or right lock , would all knock when passing the central position, very disconcerting when coming to a bend, the missus also noticed it when we was driving along"The UK,s 2nd Most Easterly Stag" Quad Exhaust- ZF 4 Speed BOX
Originally posted by MandM View PostIt's the bit with the white seals on it could not find any info on taking this apart and repairing, unless someone knows better?
[ATTACH=CONFIG]40502[/ATTACH]
I had exactly the same problem, and in my case squirting the UJ's on the steering shaft in the engine bay solved the problem.Originally posted by saintstag View PostGood evening all, i have had a momentary problem a couple of times, now, with my steering. When driving along it has suddenly seemed to lock, and taken a sharp movement of the wheel to be able to turn. This happens quickly but is a bit worrying. Wondered if anybody else ad experienced this, ThanksMike.
