Does anyone know where I might find a colour wiring diagram for a mark 2 with air con?
Needed - Wiring diagram with a/c
Have you tried eBay see triumph stag wiring diagram.Prospero's Wiring Diagrams presents:11" x 17", Laminated, Full Original Color Wiring Diagrams for Motorcycles & Vintage Sports Cars!PROSPERO'S WIRING DIAGRAMS offers the Sports Car Enthusiast the finest color wiring diagrams available. Our diagrams are accurate and easy to use - based on Factory Diagrams - or we'll be happy to give you your MONEY BACK, no questions asked - whether you bought your diagram today or 10 years ago.A normal eBay search doesn't show the auctions found in eBay Stores - Click on the "HOME" button to see all my diagrams!
Click here to see what our customers have to say about Prospero's Garage Diagrams.This Auction is for a Diagram for the Following Vehicle:Make & Model: Triumph Stag, Mk II UK Market.
Years Covered: 1973, 1974, 1975, 1976, 1977.
Additional Specifications: Mk II cars, UK Market, with Air Conditioning.
The Quick and Dirty on Our Wiring Diagrams:
1. 11" x 17" - Bigger than other wiring diagrams
2. Wires are in ORIGINAL FACTORY Colors .
3. Laminated - No grease smudges on our diagrams.
4. Roll it up and take it with you on the road.
5. More than 20 years experience.
I also found that the MK2 wiring diagrams are pretty thin on the ground. I have the Prospero's, though for the Federal A/C, its OK - the wiring is accurate but the colours are not vivid and they don't indicate the main/secondary colours, a listing of colours http://socforum.com/forum/showthread...loom-schematic (post#9 and #32 where I added one or two) is handy. I also found about 10 errors mostly in pin numbers etc, but emailed them and they were receptive, hopefully they use them eventually.
If you (or anybody) go that way I can send you the corrections I found.Last edited by trunt; 1 June 2017, 02:07.Terry Hunt, Wilmington Delaware
Hi Terry and Seaking, thanks for the help. I'll check with Prospero to see if they've improved the colouring situation on their diagrams.
I found that, looking at non A/C wiring diagrams, it turns out some 40 years ago the then new 8 track player was installed with switch wiring to the coil ballast wire by the steering column (pink and white) instead of the stereo wire by centre consoles (also the same pink and white colour!). I've changed it around but still enjoying the wonderful sound of interference in the audio system.
Next wiring task once I've got the diagram will be adding a separate switch to the two A/C rad cooling fans for those hot summer days ahead...
Thanks again,,
Tariq
Originally posted by malc4d View PostI found that the diagrams in the rom where pretty good.
As far a prosperos goes its fine, and a nice big diagram that is easy to follow and is laminated for those oily fingers. its just that it's a bit difficult actually identifying the colours so the list I linked to makes that easy.
here's a nice colour diagram of a non A/C Mk2
Originally posted by trunt View PostI'm guessing that there are 2 versions out there, a 73 version (I have) that only has Mk1 info and is widely available on the web and a 77 version that I'm guessing has Mk2 info. can anybody confirm that?
https://app.box.com/s/s0cuqmsatsrnrpscelon119zrimnily7
Yes, I have a '77 one which includes Mk2 models.
Thanks for the link, that's the one I've been using so far but eventually will need the A/C wiring. I dropped Prospero a message to check some info on their chart that I'll need.
