After searching in vain for a good quality second hand exterior door handle I started asking around to see if there was a restoration process that I could take on myself.
A classic car restoration company local to me advised that there was a company called Silvabronz (in Alton Hants) that might be able to advise, so I took my handle along to them and they said it was possible for them to re-chrome a part after first being prepared using the normal car body repair process of sanding, filling and priming. The cost of plating would be around £88, so I decided to have a go.
First step is to strip the old chrome from the part - Silvabronz did this free of charge, the first picture shows the result;
Next step is to rub down the handle to remove any lumps and bumps, I used varying grades of emery cloth, the next picture typically show what was revealed after this process;
Next stage was to make good the damage - holes were backed with thin steel plate bonded using Araldite and the remaining pitting filled with knifing putty. This was then rubbed down using fine grade wet and dry paper.
Three coats of etch prime was then sprayed on, rubbing down between coats using scotchbrite, here's the pictures after completion;
The handle was then passed to Silvabronz for plating, here's the finished result;
Not a particularly cheap process but the end result I'm sure you'll agree looks fabulous and gives the car back a bit more of its 70's bling!
