Hello all,
After first installing a starter relay, then installing new brushes and new relay, I hoped my stag would start for the coming years. No such luck! It have developed from not starting on the first try from time to time, then more troublesome to yesterday when I almost could not make it start. I suspected the ignition switch, so did the usual jiggling of the key, and sometimes it seemed to do the trick and the car started. But sometimes I could hold the key still in the start position and after a while the car started!
I went under the car and at the back of the ignition lock with the voltmeter today and did these measurements:
Big Red wire on back of the ignition lock: stable 12,5V
Big red and white wire on back of ignition lock when key turned to start position: stable 12,5V
Big red and white wire connector to starter solenoid: fluctuating 1-9V
Checked the relay against the big red wire on the starter solenoid: clicking
Tried to bypass the starter relay with the original setup: no start
Sooo I think there is something going on between the ignition switch and the solenoid. Any suggestions where to start looking? Are there any connectors between the ignition switch and the starter. When I think about it now there is one not far from the ignition switch, I will go and check this now.
If anyone have any suggestions I am happy to hear!
