Rubber Bonnet Seal
    Rubber Bonnet Seal
    Hi All, What is the preferred adhesive for gluing on the Rubber Bonnet Seal? All the ones I have looked at are unsuitable for use with cellulose paint.
    Thank you
    Ray Smith
    I used EvoStick on mine, it's still there after 10 years or so....
      EvoStik works.
      Edit: well, it used to years ago, but they have changed the formula in the recent past so it might not any more.
        Speak to your local body shop and find out what double-sided sticky tape they use. Sadly the OE seals aren't available any more; they clipped in place.
          Hi Ray,
          Try Upol Tiger seal polyurethane adhesive and sealant. (cartridge tube) I used it on my E- type hard top the night before I came away on holiday, I stuck the chrome rear screen surround to the new screen rubber which i also fitted with it. it sticks like s#it to a blanket.. It took 4 days into my holiday to get the last of the remnants off of my fingers!!!!
          Work Excess can be cleaned off with white spirits immediately. it also comes in white or black. I will be using it on my Stag seals when the time comes...
          Paul
            UPDATE,
            Hi All, thanks for your replies, did look at evostik but label said not compatible with cellulose. Only had ends to do that were coming detached. Used super glue seems to be holding o k.
            Ray
              I couldn't get on with the Tiger Seal so I found some trim clips that fit the holes and cut a cross in the base of the seal to slip the clips in and attached it with them.
              Clips from Ebay "25x Push Fit Trim Panel Clips- 3-5mm Hole- 14mm Head"
              20170725_140837
                I resprayed my car with celly and stuck the seal with Evo stick and no problems, think they just might be covering their asses.
                  Would the tool fund consider making the clips?
                    As the original seals are not available my guess is no to the clips..
                    I used 3m double sided tape..
                    Terry
                      Thank you
                      Ray Smith
                      leave it off lets heat out of engine bay
                        And engine smells in through the heater inlet.
                          This is what I used, it says foam which is misleading, but Its rather like a very thin strip of butyl rubber.
                          Find many great new & used options and get the best deals for 3M VHB #5915 Double-sided Acrylic Foam Tape Automotive 1/2" x 9/15/21/36/108 ft. at the best online prices at eBay! Free shipping for many products!
                          I used it in a number of places on the car, that seal, the plastic sheet sealing the door panels etc.. pretty useful to have around IMHO
                            Done mine with Evo stick a year ago and still perfect
                              I'm fortunate in that the one on my car is original and in good condition, fixed by the correct clips. But on my previous Stag I had to buy an aftermarket one and fixed it with double-sided sticky tape. I stayed put for many years and was still there when I sold the car.
