Carb. breather. Quick query.
    Checked that the engine breather pipes from the carbs were clear. Then blew into the carbs. One was quite free requiring no pressure at all. There was some resistance to the other.
    Would appreciate if someone could advise which is correct.
    Thanks.
    Brian. I had to find out, so have just been out to the garage to blow down my breather pipes.. There is a small amount of resistance down each, as though the pipe was smaller at the other end from where the hose fits, but the resistance is the same on each. There's another job for you then!
      Many thanks for that Mike. Now I know which one is in need of attention. Problem is I may have to do both just to find the difference.
