Electrician required
    Been working on my stag and think I have blown something as she won't turn over just get dash lights and a click, could do with someone local to Shepperton Middx to have a look as I'm stumped 😞
    Do you get "click click click" when you turn the key?
    If so it's a standard problem.
    Ensure you haven't drained the battery doing whatever you've been doing.
    Ensure all the connections on the battery and at the starter motor solenoid are really clean, and if necessary there is a block connector, or four (I think) bullet connectors located under the car just where the bulkhead curves around on the wires to and from the starter solenoid - clean those too.
    Those things should do the trick, unless the ignition switch itself is at fault, or the starter solenoid faulty.
    If all was well beforehand though the clean up should clear it.
    I have fitted the EJ Ward relay kit that lessens the load through the ignition circuits which also helps eliminate the click.
    Hope this helps
      could try cris is in shepperton 07541171493 hope it helps
      richard
        Ok , thanks
