We have owned a Mk2 Stag Auto for 31 years and completely refurbished it in 1994 including engine, gearbox, axle, steering, brakes and all accessories.
The carbs were overhauled and Piranah electronic ignition fitted, new plugs, leads, HT coil
It only gets driven less than 500 miles each year and it kept under cover in a garage.
We had an issue a few years ago whereby when the engine got hot and you put it into Drive, the engine cut-out. Starts easily and revs easily but will not run under load.
This was initially traced to the HT coil and that has now been changed several times.
Problem re-occurred sometime later and the Home Tune guy eventually tracked the issue to a hairline crack in the rotor arm and that was replaced and all was good for a couple of years.
The problem has re-occurred recently.
Replaced the HT coil, fitted a new rotor arm (The Red Rotor Arm from The Distributor Doctor), replaced the rubber diaphragms in the Strombergs just in case.
And yesterday fitted a new Piranah electronic ignition just in case the old one was failing.
Car started first pull and left it ticking over on the drive.
After 15 minutes all was well and it pulled away and drove properly.
After 35 minutes it cut out.
Leave it 30 minutes to cool down and it starts and drives properly but as I don't want to get stranded anywhere, I have not tried it on a long run.
Does anyone have any suggestions as to what the problem may be?
