Yep, the good old White/Blue Stag is still with us. With early retirement I'm finally finding time to pursue the odd niggle here and there.
As I'd mentioned once or twice, I have a problem in that the engine doesn't really run smooth and is very sensitive, sometimes dying when pulling out at a junction. I've been narrowing this down to the carbs - and not just the fact that I eat too many.
As some may remember, I got my overhauled carbs 'ready to use' from a dealer with good reputation. At that time (a few years back) I noticed that the float chambers were missing their bungs. I guess I'd have noticed that pretty quickly if I'd have fitted them. Bungs came in the post and I fitted the carbs, only to find fuel pi$$ing out of the float chambers. Taking them apart, I saw that new gaskets had simply been fitted on top of the remnants of old gaskets. Whilst I was in there, I checked the float heights - they were way different LH to RH.
I guess you can now understand why I don't 'trust' my carbs!
Tonight, I decided to delve in to the matter more deeply and remove them. One of the dashpots had been continuously losing dashpot oil pretty quickly. I now know why - one of the 'O' rings on the needle adjustment collar isn't correct - you can see from the (bad) photo that it doesn't protrude beyond the brass collar (the lower collar in the pic). Now I've gone further and looked at the jet heights - one is recessed 1.65mm and the other 2.2mm. All in all, I'm now getting very optimistic about being able to improve the Stag's running!
