Still trying to resolve the heavy thumps and clonks engaging forward or reverse on my type 65 auto. This does not happen when the gearbox is cold but gets worse as the gearbox gets hotter. I am thinking now maybe it is to do with the oil cooler? Mine is looking pretty tatty so I think I will change it anyway but in the meantime I notice the cowl bolted on to the bottom of the radiator frame looks perfectly positioned to prevent air flow to the oil cooler? What is the purpose of the cowl and would it cause problems if I took it off, maybe cause an issue with the fan or something. Has anyone removed it and if so did it cause a problem?
Many thanks
					Many thanks
