Good morning all
I am fitting a new accelerator cable and wondered about a couple of things re positioning.
I think the one already fitted was a PO fitting so not put in the original position.
Can anyone tell me please?
a) How (if indeed at all) does the outer cable secure to the bulkhead?
b) Should the cable be clipped anywhere in the engine bay before it get to the first point on the throttle linkage?
c) At the point that the outer cable cover reaches the throttle linkage, what should stop it moving through the hole in the linkage (if it is not secured to the bulkhead)? The PO had a washer positioned just before the linkage to stop the outer cable passing through the linkage but this seems sloppy and incorrect to me.
I have looked at various pictures but nothing details the correct (possibly missing item) to do the job.
Lastly do you take up all the slack in the cable making sure that the pedal is at its highest point before securing the cable with the screw?
Thanks in advance.
Mick
Thanks in advance.
Mick
