I recently fitted a Revotec fan kit with thermostat in the top hose.
I wanted to know when it comes on (partly so I could set an appropriate temp for it to come on), so I wired a lamp to the positive wire on the fan side of the relay.
The lamp comes on fine when the fan runs, but I also noted that it starts glowing after about 30mph and gets brighter the faster I go (even though the fan isn't on).
I assume the fan must be spinning due to the force of air due to the car moving and acting as a generator.
Is there anything I can do to the circuit so the bulb only lights when the fan is turned on (e.g what if I connected to the thermostat side of the relay ?)
