Hello everybody,
At the moment I am struggling with the chrome fittings around the windscreen. The windscreen is in, but the seal (2 yrs. old only!) was not okay. So there was always water coming in. We added some Teroson to the seal to make it watertight. But I simply can't get the chrome fittings back on again.
Andrew (Dasadrew") wrote that he produced two special tools for that.
There seems to be another trick with a cord laid into the outside groove of the seal to raise that outer lip.
What method or tool can you recommend? I was told that the chrome moulding should be fitted before fitting the windscreen. But this did not work, when I replaced the windscreen two years ago. The chrome fitting kept popping out again.
Best wishes,
Dieter - from Germany.
Best wishes,
