Rear Brake Adjuster Assembly
    I recently renewed the rear brake shoes and discovered that I was left with two small washers that should have been fitted to the automatic brake adjuster mechanisms. I have searched unsuccessfully for an assembly drawing which shows where all the parts go and in which order. Is anyone able to point me in the right direction?
    Separate to this I am using info in the many existing rear brake posts to help me stop them binding. This of course results in them getting hot.
    Any help?
      Thank you Mark. I'd already found the one on the left of the new shoes but not the other. Unfortunately they don't show where the small washers came from. I have found pictures of the kit of parts that are sold to totally renew the brake adjusters e.g. http://www.jamespaddock.co.uk/brake-adjuster-kit-2 These seem to have more of the small washers than I have so I wonder where they all go.
        A couple will go under the pressings, and a couple will go under the circlips.
        Andy
        1973 Stag (called Stanley), White, ongoing work in progress.
          Thank you Andy, That's what I wanted to know.
