mk1 speedo and led bulbs
    has anyone put led bulbs into a mk1 speedo with good results?
    I done this in it is now worse than before
    could you please post some pics so I can compare
    ta
    gazza
    ta
    gazza
    I used Classic Car LEDs and there was a marked improvement. I don't have a before pic but this is the after pic for what it's
    worth.
    SteveD
      worth.
      [ATTACH=CONFIG]42446[/ATTACH]
      Great thanks for that Steve they seem a bit better than mine.
      Have you driven it in the dark yet?
      Where the dials easily readable at night?
      Here’s mine with some crappy eBay leds in
      Not good
        Think you've answered your own question, Gazza. I've had good results from http://bettercarlighting.co.uk/ as have others. They do very good kits for the Warning Cluster. Classic Car LED have also had many positive mentions on here. A search may be helpful to you.
        Jonno
          Hi
          Is your instrument panel dimmer switch causing you a problem?
          Ken
            I used bulbs from Classic Car LEDs with good results, did go for green rather than white though.
            Non-standard oil pressure gauge (still Smiths) not so good, but still OK.
            Jasmine Federal Stag - TV8 - RHD and Manual OD conversion
              with LEDS the bulbs have to be the colour that you wish to see a clear LED shone through a Green filter will not be green.
              I have LEDS thoughout the car Red for brakes and rear orange for Indicators clear for sidelights etc
              They are brilliant in every sense of the word!
                [ATTACH=CONFIG]42447[/ATTACH]
                Not good
                Yes Gary it's fine at night.
                SteveD
