Restoration
    Restoration
    Hi,
    I've just bought my Stag which has been garaged for 27 years. Hardly any rust and the engine works fine, where do I start?
    hi gareth ive just moved your post to the main forum so it will get more attention, welcome to the forum maybe you could tell us about your car and add a few pictures .
    steve
      If your handy give it a big service i mean everything plugs,filters, best engine oil valvoline vr1,but you might need do timing chains unless history available and definitely should do brakes fluid, wheel cylinders everything. Dont mess with points just fit electronic ignition unit luminition off net about £30 fine if it doesnt already have. Flush the rad and change the belts, battery and check alternator. Tony Harts service DVD includes timing chain replacement and is worth getting hold of its really useful. From there run it for a while soon know what needs doing next.
        And fit some new tyres
          Yes best for sure. Check rear axel fluid and gearbox fluid levels but thinking the car starts?
            Might as well change them as well, most of the old diff oil can be drawn out with an Oil Syringe. It's a slow process, but unless you drill and fit a drain plug or take the back cover off its the only way.
              "engine oil valvoline VR1"
              Nope, too expensive, just any oil 20-50 spin the engine on the starter and build up oil pressure before running, then not until it's had a hour or two road running to clean out any rust or contamination inside the engine, then drop the oil, fit a new filter and put whatever oil is your preference in.
              Micky
