Today I found time to test my new soda blaster. The Stag intake was really bad, I have tried cleaning it with brake cleaner but it did next to nothing.
To be honest I am a bit disappointed, I had hoped that the method would be faster, and that the end result would be better. Either there is something not working as it should with my equipment, or aluminium stuff people are cleaning on Youtube is easier... I will try the Carburettor next, maybe it will be easier?
It is clear that the compressor I used is WAY to small, I had to blast for a few seconds, then wait for the pressure to build up again. I did it in a small blasting cabinet, first I used a dedicated Soda blasting gun, later i Switched to the recirculating sandblasting gun that came with the sandblasting cabinet and that seemed to work equally as well without the need for refilling all the time.
As you can see from the picture the intake did not look good. The Soda managed to remove most of the discoloratins, but the black spots it could not touch. Also the thermostat housing had ben ground once in the past and also had what I believe is rust staining from the coolant.
After blasting I put the intake into hot water to dissolve soda. I then dried it and gave it a wipe-over with Sharkhide, a product for bare metal. Hopefully that will protect from dirt getting into the porous surface.
