I’m up to reassembling after replacing chains and head gaskets. I have watched Tony Hart’s video and the Rimmers YouTube clip and read the ROM, Haynes manual and Practical Classics. All very useful for a first timer. However, I may still have a problem....
On p58 of the Practical Classics book, in a caption below an image, it states: “To adjust the chain tensioner, remove the packing piece from the tensioner, fitting 40-thou feeler gauges into the gap as you do so.” That is pretty much the method I adopted although at the time it felt uncomfortably tight and I was quite generous with the slackness. However, I neglected to check that the tensioner had actuated. The other sources all seem to allow for a more generous amount of slackness.
a) will the tensioner automatically actuate when the chains are rotated and the oil pressure builds?
b) how far out do they need to be to ensure the oil holes are clear?
The cover and crank pulley are back on and I need to decide if I should remove them again for peace of mind. Unless one of the experienced hands can put my mind at rest I guess I know how I will be spending the morning....
