auto box creeping
    auto box creeping
    :dude:hi guys , can someone tell me why my auto box is creeping forwards when i rev up?? even when i am in park??. i have just replaced the gear box, and the inhibitor switch, was is wrong??. is it the linkage, i have not change it in any way. thanks paul
    Hi Paul
    When you say creeping forward in Park, do you mean that the park lock hasn't engaged?
    3 main reasons for creep in neutral in the most likely order - wrong adjustment of selector linkage, front clutch plate clearance too tight or a distorted plate, and valve block.
    What's the history of the gearbox?
    Russ:dude:
      Hi Paul
      I agree with Russ in thatan incorrectly adjusted selector cable is the most likely
      Darren
        :dude:hi guys, i agreed it must be the linkage not adjusted right, i have changed to a rover 3.5 engine, and it must be sitting back a little so that the linkage is not right, i am going to check it out tomorrow, by jacking the car off its wheels, undoing the linkage and try moving it by hand, i can then check if it stills creeps. i might have to alter the inhibitor to suit, thanks paul
          :dude:hi guys, you were right, the linkage was one slot out. done it in ten minutes. cheers paul
