Rear End paint!
    Rear End paint!
    What is the best paint to use for the rear subframe, rear drum brakes and back plate?
    Stuart
    Hi Stuart
    I have restored an Austin Atlantic,Austin a105,Triumph Stag and am now restoring another Stag. On all of these cars I have used POR15 semi gloss. Por15 ,unless it is top coated ,is not tolerant of UV light . Its expensive and I am not sure if it is available in Great Britain but it is my first choice for the components that you mentioned,I have even used it on a stag engine block.
    Dave L
      Por 15 is available at http://www.frost.co.uk
      As dave says it is good stuff and a friend of mine swears by it,i'm currenty re bushing my front end and will be repainting my suspension parts with it.
      Stuart
        Does POR15 stand up to all weather motoring as I do not want to do the job again in a hurry and I use my car in all weathers?
        Stuart
          Stu
          It says on the tin
          "POR-15 is a rust preventive coating designed for application directly on to rusted or seasoned metal surfaces. it dries to a rock hard, no porous finish that won't chip, crack, or peel, and it prevents rust from recurring by protecting metal from further expose to moisture"
          It is a bit on the expensive side but the best products normally are
          Stuart
            Thanks Stuart
            I read that but being a sales man I don't beleive hype! But I do beleive personal referances
            I'll get some ordered up.
            Stuart
              Hi Stuart,
              I did my subframe in Hammerite Spray paint with a couple of coats of zinc rich primer first. The Brake drum and back plate I used Halfords very high temperature paint, although it has to be heated to cure properly. I used a suitable kitchen appliance for the job:shock::shock::shock:. It has a matt finish though which wasn't really what I wanted. Time will tell if it works!
                Hey Stuart, you'll have to let me know how much you use as i'll be doing mine in Feb/March,
                Cheers Baz
                  Stuart
                  I applied two coats of Rustbuster anti rust paint, followed by two coats of zinc rich primer followed by two coats of black enamel. This combination was recommended by a fellow stag enthusiast in the Derby area whose cars still looks mint six years after he restored it. I agree with your philosophy of going with personnel recommendations.
                  Bruce
                    I got all my suspension components and brake back platespowder coated in chassis black. The drums I painted in hammerite black. I haven't noticed any degredation of the finish on the drums and I drive my car fairly hard. The powder coated parts are easy to keep clean.
                    regards,
                    Raoul
