Mk1 to Mk11 Headlight Switch
    Hi Guys
    Anyone converted a Mk1 Headlight switch to Mk11. Bought a replacement but it is Mk1 plugs in OK and most things work apart from the Right indicator i can see that there is a different pin configuration and was wondering if it is a simple as moving pin around (The one i can see is a blue)
    Will check out the wiring diagram in the ROM but if anyone has done this before can you let me know
    Gary
    Things get stranger - i have checked the plug and it is deffinetly a Mk11 (White) but the pin configuration is different?
    Wondering if this is from a Triumph 2000 (or even Dolly etc)?
    Mk1 (has black connector See Picture) and mine is a white connector and plugs into the loom so will have to investigate further.
      I have used this style of switch from other BL cars. All I did was swap positions of two pins. Eachpin has alocking tab which needs to be pushed in carefully to release it.
        Thanks for the advice - will try an follow the wiring diagram in the ROM and start fiddling with the switch loom - will let you know how i get on.
        Problem with the old switch was that it just melted when using full beam? would have thought this should only operate a relay at a low current draw? any electrical boffins out there with any advice on how to stop this happening again
        Gary
          Here you go Gary - this came up a couple of years ago......
          Russ:dude:
