Having just been caught to by our wonderful British weather and having to run outside to put the hood up I felt I must post my problem to see if anyone has a solution.
My hood is incredibly hard to raise/ lower. Despite using the correct procedure and latching the rear section both sides the 'rear bar ' struggles to clear the rear edge of the stowage area and once it has been persuaded to enter its 5mins of breaking fingernails and trapping fingers etc before I can lever it out.
I eventurned up the special location screws to get the correct location ofthe frame but no difference. Also because of the tight fit the corners of the hood at the rear are permanently bent upwards and refuse to lie down on the rear bodywork.
The car has never been crashed or had major surgery so all the dimensions are standard. The only point I thing may be worth mentioning is that the pivot joints are stiff but none are broken.
So guys any suggestions? - Alan
Hi Alan -note your posting and sympathise...I too have exactly the same problem in every way you describe! can only suggest you religously follow this routine when dropping 1) unzip screen 2)lift rear to lock plates till latched 3) then release front levers 4) lif all back to tonneau folding out as you drop.... IF YOU DO IT ANY OTHER WAY... you find hood has tendency to move back slightly causing rear hoop to bind!! put back up in reverse order as described- I have carpeted inside my stowage well to protect hood!
