How do you attach a picture to a post?
Attachment if picture
Reduce your image down to less than 500k so its small and then click on the browse button as underneath here and then it will ask you for the location of your image and then you just clock OK and then send.
If your attempts have failed, its most probably because the file is too big
Good luck
Andrew
You can also put your picture on a site like http://www.flickr.com and the paste the URL of the picture into the dialog produced when you click on the picture ICON (red ball, 2 green balls). Flickr will give you the URL below an "all sizes" view of the picture. This allows you to put up a high res picture above 500k because it isn't actually in the forum.
Al
Press browse on the bottom of the post window then select the pic you want from your documents file. You must make sure it is less than 500KB which if you place your arrow over the picture before opening it will tell it its size.
If to big right click and edit the select image in the top tool bar and then stretch/skew you can then reduce the size of the picture (normally I put 50% 50% in both boxes and it's fine).
Stuart
