Just got mine back together after the viscous coupling failed and have been out on the inaugural run on quite a warm day. Wow, what a differerence a new one makes!
The amount of air being shifted around is muchgreater than previously, plus I'm running about a needle width cooler than before. Until the bearing started to disintegrate, mine seemed fine, but obviously not as good as it could be. Previously I'd done the usual checks, but the replacement will only rotate throughabout 1 blade if you spin it by hand as opposed to3 or 4 blades on the old one.
It seemsto me that they lose effeciency over time - 30+ yearsof spinning is a long time- so maybe worth changing every now and then like timing chains?
