header tank
    picture uploaded now alan
      A bit late to reply to this, but that looks very neat. Did you use the bracket from the TR7 or make your own?
        hi
        it is standard tr7 bracket
        alan
          Hi Guys
          Fitted a Cosworth 2WD Header Tank - had the rad modified with a lower feed and also a M22 threaded joint for fitting the Thermo Switch for my Kenlow.
          Works a treat - drops the System Pressure and now always run in the "E" at all external temperatures.
          Lower Header Tank Feed back to Radiator
            GT
            Thats a great fit ,well done.
            Cheers Steve
              Hi GT, Whats the pressure rating on the cap ?, Does this tank have just the two outlets on it that you have plumbed into the top and bottom of the rad ?.
              I think this tank looks much better then the square Volvo one I have.
              Sukh.
                Sukh.
                Hi sukh
                The Pressure rating is 18PSI so the hoses are not as hard as with the std 20PSI Cap - There is a Top feed as shown into the Radiator inlet and a lower feed to the bottom of the Radiator (Bottom of the Radiator on the Filler Side) This ensures that there is always a head of water above the pump & Thermostat so it avoid cavitation.
                Gary
