I am servicing the Stag this week after trawling the forum this is my list.
Air filter
Oil and oil filter change
Spark Plugs
Petrol filter
Reverse flush of the cooling system, Antifreeze corrosion inhibitor for aluminum engines
Grease points;
Driveshaft’s UJ's on Prop shaft (2) and half shafts (4) you need the flexible bit to get to the UJ in the trailing arm.
Hand Brake cable in the yoke above the prop and where it goes through the sub frame.
The splines on the Half shafts need graphite grease or CV Joint grease
Two lube points on the top swivel bushes in the inner wing turrets
Gear box fluids change
Rear axle fluid change?
Breather (The breather is on the top of the differential casing, near the right rear corner. Check that the pin is loose in the breather hole)
Brake pads check
Have I missed anything?
I want to cover as much as I can as this is my 1st year of ownership and I don’t know what has been done/checked before.
Air filter
Spark Plugs
Petrol filter
Grease points;
Brake pads check
