Paint prep.
    Paint prep.
    Hi,a call to our resident paint guys, is finishing prep with 800 grade wet, good enough for cellulose? :? Martin.
    Martin
    I'm no paint guy but if you are flatting primer prior to top coats then I think that 800 wet is OK or go one better and use 1000 wet.
    Les.
      That's 200 better isn't it?
        Kevin
        That must be the outcome of a poor northern education, being unable to count any more than my digits allow.
        Les.
          You can count to 1023 in binary!
            les M wrote:
            Martin
            Les
            1000 is to fine it will not let the paint adhere to the primmer you need 800 or better still 600
            JOHN
