Front Wheelbearings
    Front Wheelbearings
    Hi
    HELP!!
    I am trying to change the front wheel bearings on my car.
    One side done no problem but on the other side I cannot sererate the main axle shaft from the spider it seems to be solid.
    My question is do you need to seperte this or can I reasemle with it as it is?
    Worthers
    Hi Worthers
    Do you mean the hub will not come off the stub axle 154474? Then you need a three jaw puller and it will come off no problems
    If you mean the stub axle from the vertical link 209344 then once the hub is removed and the stub axle unbolted hit it from the back with a rubber mallet or plastic hammer and it should come out.
    The Stub axle does not need to be replaced unless damage/worn so just replace the bearings.
    Stuart
      Hi Stuart
      Thanks for the quick response.
      The stub axle will not come off the vertical link no matter how hard I seem to hit it!
      There is no obvious rust just seems jammed on!
      Derek
        Hi Derek
        If it is not damaged just reassemble your hub with new bearings.
        If it is damaged you need to warm the localised area up with a gas torch then hit it!!!
        Stuart
          I havre tried heating it up but cannot get enough heat with just a blow torchI
          As it seems otherwise OK I'll just reasemble it.
          Many thanks for your help.
          Derek
            Success!!!!
            Lots of heat and a bigger hammer!!
            Thanks for the advice.
            Derek
              Hi Worthers, welcome, I'm very curious to know why you wanted to removethe stub axle? Not normal procedure when changing wheel bearings and it's such a lot of work ? Martin.
                Hi Worthers and welcome, i see the Hammer wins again:dude:
                  Hi Martin
                  The whole front suspension is stripped right down and being refurbished or replaced and when I took the first hub apart the stub axle came out easily so I just assumed that the otherside should do the same hence my original question.
                  After that is was a case of it was going to come apart like it or not!
                  Interestingly the old bearings were black due to running very hot not a problem I was aware of!
                  Derek
                    Hi Derek, thanks for that, I know what you mean, once started I refuse to give up ! If the bearings were black, there's a possibility the stub is damaged, especially if the inner tracks had been turning. Good luck, and above all else - enjoy. Martin.
                      Alternatively the bearings may have been tightened too much causing overheating. I always run them on the slack side, although MOT testers can complain about too much play.
