Hi - back on the Stag now!
I am just in the process of putting in a Immobiliser. Standard sort that isolates 2 circuits - starter and one other ( eg.fuel pump or ignition). Instructions are fairly vague but it seems you just cut the wire you want to isolate and connect the two ends to the two relevant wires on the unit. It says 18amp relays are used for these circuits which I assume are in the unit.
My slight concern is that the white/red wire for the starter solenoid on the Stag are a lot thicker than the ones on the immobiliser which I would have thought were a bit thin for 18amp but I am only guessing!and is 18 amp enough?
Anyone else fitted their own and come across this? Or am I worrying about nothing
