Hi, I need a bit of help here, I bought the Stag with a Kenlowe fitted. The way it is fitted is as follows;....The kenlowe fan is fitted behind the radiator, it has 4 bolts going through the radiator and fitted on with round wing nuts, then the original fan is where it is.
Is this usual ? because I had a Rover P6 with a Kenlowe and it was not fitted this way. Also behind the radiator above the Kenlowe fan in question there is a little cooler unit ( looks like a miniture radiator )is this part of the kenlowe package?,.Lastly I am going to polish the stat housing and may change the stat if required, how do I decide which stat to use? the 75 or 82 degrees.:?
As always your thoughts and feedback are much appreciated from a Stag newbie.
