diff extension housing overhaul ; quillshaft bearing
    hi everybody ,can the quillshaft bearing be a source of amild noise coming from the rear ,i already have this unit strengthened ,but im suspecting the bearing is worn ,how easy or hard is this job once the housing is out ,or do i not have to remove the housing to renew the bearing ??? who suppllies these parts ??? many thanks .graham
    Hi Graham
    Once the unit is removed it takes about 5 mins if that to knock the old one out and put the new one in!
    Easy job as long as you have circlip pliers, hammer and a drift.
    If you are getting a slight whine and drumming noise it is most likely to be the quill shaft bearing.
    Procedure is;
    • Remove circlip from front of bearing
    • hit the rear of the quill shaft (bit that mates with the diff) until the bearing is protruding about 3mm from the diff nose casing.
    • Hit the front of the quill shaft to remove it.
    • Drift bearing out from the rear.
    • Using a block of wood replace new bearing
    • Replace circlip
    • Replace Quill Shaft
    • Suggest you replace diff oil seal at same time.
    Stuart
      thanks stuart ,very helpful !!! graham
        One thing I discovered when I was doing mine was that the smaller washers from the main subframe mounts (WP828 and WP817) are the perfect size to use as a drift. No likelihood of leaving splinters in the bearing either then :P.
          thanks dave ,excellent ,thanks for photo !!!! reguardsgraham
