Evening
I know some of you have been able to trace or are considering tracingthepast owners of your cars and gain some insight into past modifications, repairs, replacements etc so I thought I'd try and pick your brains over this.
I have just received from the DVLA a VQ7 which lists allthe previous owners back to 1976. I'm number 7.I now intend to write a covering letter to each address explainingwhat I'm trying to achieveand apologising if the letter is mis directed, untimely or inappropriate. (I'm thinking some of these people might be dead!)
Then I'm going to include a blank proforma that makes enquiries regarding different areas of the car that might have had major work done on them. This is where I need the help. What do you think I should list? So far I've thought of:
Cylinder heads, timing chains, water pump,radiator, clutch, gearbox, diff, ignition system, panel replacement, welding, respray, suspension
All ideas from all forum members gratefully accepted (hope you enjoyed Stoneleigh)
David
David
Martin.
