My final problem you'll be pleased to know is case you're getting fed up with my posts...
Any ideas on how to reduce slack in the steering system?
I overhauled the 2 racks I have (different pinion types), replacing seals, resetting rack movement with micrometer, I didn't replace bearings as looked ok.The first rack has a lot of vertical play in(pinionend of rack) shaft (not the balljoint), it was touch and go on MOT last year. The only way to reduce to anything acceptable is to adjust the thrust on the rack shaftto the point where rack will hardly move. Its as though the thrust pad is moving inside the rack allowing the vertical movement even when tight.
The second rack, again correctly adjusted seems to have excessive play on the input shaft, as though thepinion is moving to much before turning the gear. This leads to vagueness in steering control. Does the torsion bar become weak?
I should add that the column is fine, intermediate shaft replaced along with column bearings, little slack in sliding joint.
I'm getting to the point of just buying a recon rack but don't like being beaten!
Any ideas welcomed.
Any ideas welcomed.
