When changing my discs, i found the stub axle looked as in the attached photos.
I believe the black is from the hardening from new and that the stag stubs where harder than other triumphs- is that correct?
There are indentations/ dentson the stub,I replaced the outer bearing race as shown and where that rests on the stub there are no marks.
Are these normal, is the stub axle ok or do i need to replace it??
as an asside, when i put the calpier back I was scratching my head for half an hour figuring out why I had a "bent" caliper as it did not sit paralel to the disc as shown below. look at the bottom of the photothe disk is near touching the caliper. thought i had a big problem.
It turned out the disc backing plate (stone gard) mount that runs throught the caliper bolt was missing at the bottom (but present at the top), so the caliper was a mm closer at the bottom. looking at the old pads it had been assembeled like this last time!!!
I fixed with a washer for now.
