Hi, Apologies but I haven't taken a Stag engine apart before...
After fitting a fully rebuilt engine I boughtthat had been stood for 5 years, although the engine was from a reputable supplier, I had an overheating problem in less than 100 miles of service (after torquing the head down three times).,( I saw a blast of steam exit the exhaust as I coasted the car in to the roadside) I was told the cause may be the water pump,as the car overheated so quickly on a 5 mile jouney unfortunately I have sheered the head off the bolt holding the pump impeller in! (it was a left hand thread), any ideas how I can get the pump out? Maybe it was ok anyway, it spins freely andfeels OK, I see from an engine diagram it meshes with a skew gear ona timing chain pulleybut surely it would spin when I turned the engine over with the cover off, it didn't though, is this correct?
I tested the thermostat and its fine, it looks new.
Luckily I got the studs offLeft Hand head easily (using two nuts method), I was shocked how corroded the stud threads werein the block, when I reassemble should I apply a barrier grease, say copper or graphite to assist the next person (maybe me again ) taking the studs out?
I pressure tested the pots (cold) before starting the work, they were all 125-145 lb, except two that were 105lb. I imagine these were the two that blew unfortunately one on each head. I notice on the left bank the 1st pot (nearest the bulkhead) is extremely close to a water way, is this a weak point? I cant see the gasket breach anywhere as the engine wasn't run long enough.
I haven't taken the right hand off yet.
Appreciate any advice as I am stuck with doing the work on my own.
