Tie Bar bushes
    Tie Bar bushes
    The cars in need of it's MOT soon so I thought I'd look at last years advisory notice.
    "Wear in front tie bar rear bushes"
    I'm confused... is this the tie rod and can anyone explain which is the rear bush. If someone wouldn't mind pointing out where this is on something like the Rimmer Bros exploded diagram I would be eternally grateful. Then I can get some ordered and have a go at replacing them.
    Thanks David
    138143 x 2 each side
      Thanks a lot MB
      So the MOT tester means the drag strut really??
      Is it also known as a radius rod?
      David
        David
        It's an easy job to do, did all my front bushes last month (rubber on the drag strut and poly on the others)brought from Peter at www.ldparts.co.uk
        While you have the drag strut off check the condition of the track control bush, anti roll bar link and bottom ball joint change if need be while our at it
        Stu E
          Thanks Stu
          I rang Peter today (he's always helpful) but thencouldn't remember what the advice note had said duh.
          I'll give him a bell tomorrow and get some ordered
          David
            David
            You right about Peter he is a top bloke and always my first port of call when needing bit's, when i ordered my stuff for the front, bushes, shocks etc he even offered to personally deliver them fochas he was passing Stafford on the M6 later in the week
            Now thats what you call customer service
