hi everybody,
I have a slight problem it isn't major ,just rather annoying.I have a stag it's just done 87000 miles and does not seem to burn a lot of oil and has no undue rattles,so I assume the motor is in reasonable nick (ahem!)
the problem I have is when the motor is up to normal operating temperature (needle halfway on the gauge) there is occasionallyan annoying hesitation,it occurs when I putthe throttledown quick during an overtake or pulling away from a junction, (if I need to get out quickly) .if I ease up on the throttle it becomes very smooth again.When the engine is cold and warming up there are no such problems.
I have replaced carb diaphragms,sparkplugs,plug leads,coil,distributor cap, checked mixture,timing(electronic) and timing advance.and checked the dash pots.
any ideas? could it be the ignition system? or is this a characteristic to live with,due to the modern unleaded fuels?(possibly pre-ignition?)I use castrol valve master plus which "seems" to help but maybe I'm kidding myself!!!!!!!!
what is the best fuel to use?
thanks
allan.
thanks
allan.
