Rear Shock Absorber
    Rear Shock Absorber
    Hi everybody,
    I am a new forum member from Germany (Munich) and this is the first time that I try to get a technical advise via this forum. I am going to renew the rear shock absorbers and would like to know which brand is advisable for maximum comfort (Spax, Koni, Gaz...) I am not a fast driver so cornering is not so important. At the time being I have Monroe shocks installed and I find them rather uncomfortable.
    Hope to hear from somebody, Klaus
    Willkommen, Klaus.
    Nice to get someone from Germany on board. This is becoming quite an international Forum now.
    Personally I have had no adverseproblems with 'standard' rear shock absorbers as available from most of the usual Stag suppliers, and also from many other outlets. On my last Stag I fitted Boge units and found them fine as well. My current Stag has Gas-a-just units. Whether they have gas in them or not I don't know. They don't appear to be adjustable though. They can be got from James Paddocks and give a nice comfortable ride.
      Hi Klaus.
      Welcome. Are they too hard or soft? I fitted Spax adjustables on the rear, 4 clicks from minimum out of 28. They are fine.
      John.
        Hi John and Dave,
        thanks for your answer. I find the Monroes too hard. Concerning Spax: Tony Hart told me 10 years ago that Spax with 3 clicks are excellent for cruising on country roads. That is the same experience which you have made. At that timeI could not get Spax in Germany which is not a problem now. I think I will go in this direction.
        Klaus
          KOY 23 wrote:
          Hi Klaus.
          John.
          I use Spax too. On my previous Stag they made such a difference to the ride having followed the HRS recommendations. (3 clicks).
          My current project will certainly get a pair. They seem to have shot up in price recently - anyone know of a good place to buy them these days?
          PaulT
            Hi Paul
            do you think 59.99 incl. VAT + 15.00 delivery is to high? Offered by http://performancedirect.potn.co.uk
            Klaus
              I got mine from LD parts
                Hello Klaus.
                Thank you for the info that 3 clicks is suggested by Tony Hart. I just set mine on 4 as a starting point and never bothered to change them. Click 28 must be rock hard!!
                  Klaus Schlüter wrote:
                  Hi Paul
                  Klaus
                  Hi Klaus
                  The fronts are £91.99 at performance direct, last time I brought a set I seem to remember £65 so they have gone up quite considerably.
                  PaulT
                    Hi Paul
                    Klaus
                    Hi Klaus
                    PaulT
                    .... and £15 each for postage. LDPart will be cheaper overall, and great service.
                    PaulT
                      PaulT wrote:
                      Hi Paul
                      Klaus
                      Hi Klaus
                      PaulT
                      PaulT
                      According to Rimmer site Spax front inserts are £35!
                      http://www.rimmerbros.co.uk/cgi-bin/...tag/susp-front
                      And wait for it £199 for the pair from Monarch!:shock:
                      http://www.monarch-stags.co.uk/index.html
                      Stuart
                        Stuart
                        Stuart, LD 's are £101 each for fronts,so the same as Monarch's ,but this post is about rear shocks which are £145 pair from Monarch and £57 each from LD.
                        LD have to be the best bet for rears at the moment and as stated ,great service.
                        Cheers Steve
                          Stuart
                          Cheers Steve
                          Hi Steve
                          Don't blame me Paul T mentioned the fronts:P
                          Stuart
                            Stuart
                            Cheers Steve
                            Hi Steve
                            Stuart
                            I'll let you off then,just this once
                              Just noticed that the LD price is plus vat so not much in it .
