White marks on vinyl roof
    Hello
    My hardtop has a black vinyl covering which is covered in white marks, I believe caused by condensation. Nothing from the Autoglym range seems to shift them. Anyone have any ideas??
    Thanks in advance for any replies.
    Boot polish?
      Out of interest, what is underneath a vinyl hardtop- is it just a normal metal hardtop?
      Is it feasible to remove the vinyl, and then paint the hardtop body colour?
      Rgds....Al.
        Tried that, looks great for a while but soon fades, was hoping for a more permanent solution, cheers anyway
          Hello, its a standard top, just vinyl covererd
            Have you tried using a stiff brush with some detergent? After that, try black valeting dye.
              Rgds....Al.
              Al, Are you thinking of our hardtop . If soI willneed to get it back to you so you can get itsprayed with the rest of your car.
              I can answer the question of what is under the vinyl (no I didn't peel your vinyl off to find out!) I had a factory vinyl covered hardtop come with my car. It had spent its entire life outside propped up against the guys garage and it was completelyrotten. I pulled the vinyl off and the steel underneath had the lightest cover of red primer I have ever seen. The vinyl was easy to remove but the glue takes much longer. I started doing it and realised the rot was so bad I chucked it.
              - Alan
              PS if you are going to have your hardtop sprayed bodycolour remember my bodycolour is white!
                Rgds....Al.
                - Alan
                Alan,
                I was thinking of our hard top, yes. My apologies for being presumptious about re-spraying it.
                Not having see it for so long, I was just wondering what was underneath, and also exploring the options of what to do with the Lion claw marks:P
                I always thought red and white went well together, like the cross of St George!
                Al.
                  arbman101 wrote:
                  Rgds....Al.
                  - Alan
                  Alan,
                  Al.
                  Ideal compromise - I assume you mean spray it white so that your Stagwill have your favoured'St George' configuration. I'm afraid spraying it red would simply not do, the red over white on my carwould give it totally the wrong look, like a monstrous boil on anvirginal whitebeauty.
                  - Alan
                    alan_thomas wrote:
                    arbman101 wrote:
                    Rgds....Al.
                    - Alan
                    Alan,
                    Al.
                    - Alan
                    What is virginal about it??
                    Last I heard it was totally f**cked :P:P:P
                      arbman101 wrote:
                      alan_thomas wrote:
                      arbman101 wrote:
                      Rgds....Al.
                      - Alan
                      Alan,
                      Al.
                      - Alan
                      LOL
                        Try a Mr.Muscle/CilletBang-type bathroom cleaner - usually works - try a small, less noticable, areafirst though
                        ......Andy
